AMS Goodies in Stock for the Evo X!
In stock and ready to go!
This is the first step in modifying your EVO X. The AMS EVO X intake pipe is designed to improve air flow to the turbocharger and increase horsepower and performance. We installed the AMS EVO X Performance Intake with an AMS Manual Boost Controller set at the factory 21 psi on our shop car and produced a tremendous 45 awhp over stock! The boost held better with the MBC and didn’t taper as much as it did with the factory boost control solenoid.
The AMS EVO X Performance Intake is professionally TIG welded in house by our master fabricators. High quality polished 3” mandrel bent aluminum is used in construction and the pipe ends are bead rolled for a great fit and easy alignment. A K&N free flowing filter is included along with all new 4 ply silicon couplers and new hose clamps. Another fine point is the BOV recirculation tube entry angle which is completely in-line with the air induction path avoiding turbulence and maintaining excellent air flow.
Remove clutter and simplify your engine bay while adding horsepower!
Professionally TIG Welded
3” Polished Aluminum Mandrel Bent Piping
CNC Aluminum MAF Sensor Flange
Bead Rolled for Better Fit and Alignment
Boost Source Port
Crankcase Breather Port
High Flow K&N Air Filter
4 Ply Silicon Couplers, Silicon BOV Return Hoses and New Hose Clamps
BOV Return Bung Positioned In-Line with the Induction Path Doesn’t Interrupt Air Flow
The intakes we received all incorporate bungs on the intake pipe where you plug in your breather hoses just as they were from the factory.
In stock in polished silver and black (as shown). Silver is $269 picked up, $284 shipped in the tristate. Black is $350 picked up, $365 shipped
IntercoolerPipe:
The AMS EVO X Upper Intercooler Pipe is designed to flow more air than its stock counterpart and increase horsepower, and that it does! With this simple upgrade we produced an additional 5 awhp peak and 10+ awhp gains in the midrange! Our UICP is professionally TIG welded in house by our master fabricators using high quality polished 2.5” mandrel bent aluminum. At the pipe’s beginning we designed a smooth, non-turbulent 2 – 2.5” transition for maximum performance. The pipe ends are bead rolled and the assembly is mounted to the core support (in the factory location) to help prevent couplers from popping off under boost. We also utilize a “hump hose” coupler to cope with engine movement so you won’t have to deal with torn couplers. All the factory couplers are replaced with quality 4-ply silicon pieces which can endure 50 + psi!
2.5” Polished Aluminum Mandrel Bent Piping
Genuine CNC AMS Badge
Bead Rolled Pipe Ends
Factory-Style Core Support Strap
4 Ply Silicon Couplers and New Hose Clamps
4 Ply Silicon ”Hump Hose” Coupler For Engine Movement
Smooth 2 – 2.5” Transition For Unmatched Air Flow
In stock in polished silver - $279 picked up, $299 shipped
Alaska, Hawaii, Puerto Rico, Canada, or other locations outside the 48 states, please contact us with your full address (not just a postal code) for a shipping quote.
To order, just give us a call, or you can send paypal to z1sales@z1auto.com. These are in stock for immediate delivery/pickup
Thanks!
Boost Source Port
IntercoolerPipe:
Thanks!
