Agency Power Short Ram Intake
Agency Power Short Ram Intake Kit Mitsubishi EVO X 08+
Adds Approx. 20whp / 16ft lbs Tq.
Available in Red Powder coated or Polished finish. In Stock Now!!!
The short ram intake features an aluminum intake pipe with a CNC machined aluminum MAF sensor adapter. The factory MAF sensor fits securely into place with provided hardware. To keep cool air directed to the intake system, AP has retained the factory air inlet scoop similar to the OEM air box. The air scoop snaps into place on our aluminum heat shield like factory. There is no cutting or altering your OEM components. The heat shield is designed to keep cool air going into the intake system. Using the factory rubber grommets and mounting positions, the heat shield will drop into place for a secure fit. AP uses high quality cone air filters for this EVO X intake system. The air filter features a 3 inch front funnel style inlet which is perfect for the direct air flow coming from the front of the car. The filter fits on to the 3 inch intake pipe with a simple worm clamp. The intake pipe diameter is increased to 3.25 inch on one side to fit the factory rubber suction pipe. It can also be used with our aftermarket suction pipe using an AP silicone coupler to connect the two.
