Cosworth Evo X Intercooler Hard Pipe Kit (clearance)
The Cosworth Mitsubishi Evo X Intercooler Hard Pipe Kit features large diameter, single piece, aluminum tubes. This kit is designed to decrease turbo lag and increase power in your 2008+ Evo X GSR/MR. The Cosworth hard pipe kit provides all the hardware needed for a full install with the stock intercooler or the Cosworth Intercooler Kit. The long flexible bypass hose is no longer pressurized, as we've relocated the air bypass valve mounting to the hard pipe itself. The pipes are powercoated in a clean metallic silver finish to brighten up any engine bay.
- Large diameter mandrel bent aluminum tubing with silver metallic powder coated finish.
- Bypass valve relocated to hard pipe
- Factory bypass hose no longer pressurized
- Improved response and power
- 4-ply heavy duty silicone coupling hoses.
- Liner hose clamps.
- Compatible with stock intercooler setup and Cosworth intercooler
- Comprehensive instruction manual
- 2008+ Evo X GSR / MR models
Please PM for special clearance pricing on these. We only have two sets at this pricing!!
