Extreme PSI - Moroso Catch Tank
Old Mar 31, 2012 | 05:00 PM
extremepsi's Avatar
Gold Sponsor
Moroso Air-Oil Separator at Extreme PSI
This bolt-on Moroso air-oil separator will help keep the oil out of your intake tract. Stock Evo's vent the valve cover back into the intake tube which over time will cause a buildup of oil residue and reduce the efficiency of your intercooler. The Moroso Air-Oil separator is the solution. Keep the stock configuration for superior crank case ventilation but separate the oil from the air using this unit.
Air-Oil Separator
Fits: Mitsbishi Evo 10, 2008-Up
3/8" N.P.T. inlet & outlet fittings, 36" of 3/8" rubber hose
Installation Instructions
Click to buy!
Thanks,
Tony
www.ExtremePSI.com
1-800-PSI-4502
215-244-4295
sales@extremepsi.com
