ETS Evolution X Turbo Kit and Replacement Manifold - Sneak Peak!
Hopefully, all the X testing will be done early part of next week. I will update when I have results. We plan on testing out the new manifold and o2/downpipe at this time.
2009 is going to be a great year for the X
Thanks Buddy!
We are going to do a couple tests to see how the heat reacts with the stock lines, if needed a heat shield will be included. The reason we went with a top mount was to keep the heat away from the firewall. The manifold contains most of the heat.
Adapter pipe w/ couplers for the stock intake.
4.0" intake w/ stock mas adapter.
4.0" intake setup for engine management system that use no MAS.
The 4.0" pipe matches the inlet size on the turbochargers, which will result in less turbulence and smoother flow.
, great work
