2008 Mitsubishi Lancer Evolution - Technical And Mechanical Specifications (Prelimina
Engine Type 2.0L MIVEC I4 turbocharged/intercooled
Engine Code 4B11 T/C
Valve Train DOHC, 16-valve, Mitsubishi Innovative Valve-timing Electronic Control system (MIVEC)
Displacement (cu in./cc) 122/1998
Bore x Stroke (in./mm) 3.4 x 3.4 / 86.0 x 86.0
Compression Ratio 9.0:1
Horsepower @ RPM (BHP) (Fed./Cal.) 295 @ 6500 (est.)
Torque @ RPM (lb-ft.) (Fed./Cal.) 300 lb.-ft. @ 4400 (est.)
Engine Block Aluminum
Cylinder Heads Aluminum
Redline RPM 7,000
Fuel System MPI
Emissions Fed: Tier 2 bin 5
Recommended Fuel Premium Unleaded, 91 AKI min.
Radiator Core size (mm) 700 x 408 x 27
Engine Oil Type 5W-30
Engine Oil Capacity (qt./l) 5.0/4.8 (filter + 0.3 qt; cooler + 0.5 qt.)
TRANSMISSION GSR MR
Type 5-speed manual 6-speed TC-SST
Ratios
1st 2.857 3.655
2nd 1.950 2.368
3rd 1.444 1.754
4th 1.096 1.322
5th 0.761 1.008
6th -- 0.775
Reverse 2.892 4.011
Final Drive 4.687 4.062
SUSPENSION GSR/MR
Front MacPherson strut (inverted strut)
with forged aluminum control arms
MR model: Eibach springs and Bilstein shock absorbers
Front Stabilizer Bar Diameter (mm) 25
Rear Multi-link with forged aluminum control arms
Rear Stabilizer Bar Diameter (mm) 23
EXTERIOR DIMENSIONS GSR/MR
Wheelbase (in./mm) 104.3/2650
Length (in./mm) 177.0/4495 (Canada: 178.9/4545)
Width (in./mm) 71.3/1810
Height (in./mm) 58.3/1480
Track, Front (in./mm) 60.8/1545
Track, Rear (in./mm) 60.8/1545
Min. Ground Clearance (in./mm) 5.3/135
INTERIOR DIMENSIONS GSR/MR
Passenger Seating Capacity 5
Passenger Volume (cu. ft.) TBD
Luggage volume (cu ft) TBD
PASSENGER SPACE GSR/MR
Front Head Room (in./mm) 39.6/1005
Front Shoulder Room (in./mm) 54.7/1390
Front Hip Room (in./mm) 53.3/1355
Front Leg Room (in./mm) 42.2/1070
Rear Head Room (in./mm) 36.9/935
Rear Shoulder Room (in./mm) 54.3/1380
Rear Hip Room (in./mm) 54.1/1375
Rear Leg Room (in./mm) 36.1/915
WEIGHTS GSR/MR
GVWR (lbs/kg) GSR:
MR:
Curb Weight (lbs./kg) GSR GSR: 3344/ 1520 (JDM Spec)
MR: 3388/ 1540 (JDM Spec)
Weight Distribution (% f/r) GSR GSR:
MR:
WHEELS & TIRES GSR/MR
Wheel Type GSR: Enkei cast aluminum alloy
MR: BBS® forged aluminum alloy
Wheel Size 18 x 8.5 in. 5JJ
Tire Type Yokohama ADVAN asymmetrical performance tread
Tire Size P245/40R18 93Y
Spare Tire T145/70R18 107M
STEERING GSR/MR
Type Rack-and-pinion, Hydraulic Power Assist
Ratio 13.3:1
Turn Circle – Curb to Curb (ft/m) 38.7 / 11.8
Turns – Lock to Lock 2.27
BRAKES GSR/MR
Front Brake Type Ventilated disc with 4-piston caliper
[MR: Two-piece caliper for weight reduction]
Front Brake Diameter (in/m) 13.8/350
Rear Brake Type Ventilated disc with 2-piston caliper
Rear Brake Diameter (in/m) 13.0/330
Anti-Lock Brakes 4 sensor, 4 channel Sports ABS with EBD
Swept Area – front (sq in) 341.6
Swept Area – rear (sq in) 267.2
Total Swept Area (sq in) 608.8
ELECTRICAL GSR/MR
Battery 65D26L
Alternator (Amps) 130A
FUEL CAPACITY GSR/MR
Fuel Tank Capacity (gal./l) 14.5 / 55
EPA ESTIMATED FUEL ECONOMY * GSR/MR
GSR: 5MT City / Highway (mpg) TBD
MR: TC-SST City / Highway (mpg) TBD
WARRANTIES
Basic 3 years or 36,000 miles
Powertrain 5 years or 60,000 miles
Anti-corrosion 7 years or 100,000 miles
Technical specifications are based on the latest information available at the time of printing and are subject to change without notice. 8/20/07
Redline RPM 7,000
Fuel System MPI
TRANSMISSION GSR MR
Ratios
1st 2.857 3.655
2nd 1.950 2.368
3rd 1.444 1.754
4th 1.096 1.322
5th 0.761 1.008
6th -- 0.775
Reverse 2.892 4.011
SUSPENSION GSR/MR
WEIGHTS GSR/MR
GVWR (lbs/kg) GSR:
MR:
MR:
STEERING GSR/MR
Ratio 13.3:1
BRAKES GSR/MR
ELECTRICAL GSR/MR
Battery 65D26L
WARRANTIES
FS[South]: greddy t67 hot parts kit
briantorres1991
Aug 2, 2016 06:10 PM
ak47po
22
Nov 19, 2007 09:23 AM
