Trouble With Safc2
wiring... check where the rpm signal is connected to.
Power (red)----pin 25
ground (brown)----pin 26 (closer to ECU)
ground (black)-----pin 26 (away from ECU)
RPM (green)-----pin 58
TPS (grey)------pin 84
Air flow signal out (pink)----pin 90 (closer to ECU)
Air flow signal in (orange)------pin 90 (away from ECU)
Knock sensor (purple)------pin 78
for some strange reason, one post showed RPM as pin 88.. http://www.evotuners.net/forums/sho...p?&threadid=111 totally screwed my RPM.. it was reading low.. switching to pin 58 fixed it..
