map 0 with 1.7 firmware w/ OLF
Old Nov 17, 2004 | 04:05 PM
SoR's Avatar
SoR
I'm a bit confused with what map 0 is on 1.7 firmware.
- If I understood correctly from the manual when OLF is off, it's same as in 1.3, everything is running of off ECU.
- but when OLF is on, is it the same scenario as above - map 0 is map 0 or does it now run some pre-set values that you cannot modify or what?
Can someone please chime in, I'd like to upgrade and turn on OLF but don't feel like doing too much tuning at the same time.
Old Nov 17, 2004 | 05:39 PM
VTECH8TR's Avatar
Map 0 is passthrough mode to the Stock Ecu. You will definitely have to tune your car if you activate OLF and change to a different map. You can set it to Map 0 and datalog timing and your AFR's. What are your mods right now?
Old Nov 17, 2004 | 07:33 PM
vletnguyen's Avatar
luis, you free weds for a datalog session? call me
Old Nov 17, 2004 | 08:11 PM
MalibuJack's Avatar
Yep.. MAP0 is completely passthrough, if you use any other map with OLF enabled, it has a background fuel map that you may have to tune for..
Old Nov 18, 2004 | 07:39 AM
SoR's Avatar
SoR
OK, sounds good, that's all I needed.
