UTEC Boost controller?
Old Dec 8, 2004 | 12:15 PM
HoLeeRay's Avatar
Well, I'm still waiting to find out whether the UTEC can be run on an '05 without problems, but I'm assuming it won't be that big of a problem. (being hopeful here) Anyways, should I get a separate boost controller if I get the UTEC or does the UTEC have a good Boost Control program?
Old Dec 8, 2004 | 01:21 PM
VTECH8TR's Avatar
The Utec has built in boost controlling features which controls the stock Boost solenoid. I made the mistake on spending $300.00 on a Greddy PRofecB Spec II, after installing the Utec it was not needed.
Old Dec 8, 2004 | 04:46 PM
TampaTurbo's Avatar
The boost controller works better if you are running in open loop boost becasue of the eraatic boost spikes but with the install of a map sensor, closed loop boost works like a charm.
