what map?
what map?
I just bought a used UTEC with protuner on sunday, the utec is hooked up but the protuner is not. I have the utec on map zero right now so obviously it is running off of the stock comp., but I was curious what map I should use or should I just wait untill some with know how and a dyno fine tunes it for me. I was guessing map one but the guy I bought it from stated that the base map is to lean. My current mods are a buschur 3in turbo back with there high flow cat and a areo turbine muffler, aps air intake, boost controller, NX intercooler sprayer and a hks ssqv with there upper intercooler pipe. Any reccomendations would be appreciated.
If his experience with the base map is that its lean, then you likely have the 1.7 firmware installed and open loop fuel installed, I would be inclined to leave it at passthrough (map 0) until it can be tuned right, its the safest bet.
how do I know what version I have? If im not mistaken i remember he said something about open loop fueling. Does any one know of a place in dallas that has a all wheel drive dyno that knows how to tune EVO's with the utec.
