super afc2 help
Old Jan 12, 2005 | 09:17 AM
20psiGuy's Avatar
super afc2 help
when u go to misc. then sensor check...what does in-1 and in-2 stand for... IN-2 always stays at .005 is that normal
Old Jan 13, 2005 | 02:39 PM
EVOTEXAS's Avatar
yes the evo doesnt use that
Old Jan 20, 2005 | 10:29 AM
03BREvo8's Avatar
EEEH Wrong.. in2 is hooked up to the O2 sensor and displays the voltage... at wide open throt youll want a .88-.91 voltage.. that should be tuned ... buying an aftermarket harness( buschur Racing 100$) will solve alot of problems.. I mounted mine in the glove box also...
Old Jan 20, 2005 | 10:32 AM
03BREvo8's Avatar
in 2 should also fluctuate from .00000- .999999 or so while your driving.. if its idle then your cars just warming up .. once its at opperating temp. it should go up and down...
