stock settings, stock car
i was looking in the fourms and i couldn't find anything for afcII setting on an all stock evo. no mods what so ever. i know that the cars are rich from the factory and i would just like some ideas for what to set it to. i know that all cars are diffrent just want baselin. thanks
For now, leave all your settings at 0% highs and lows. Get a hold of a logger then follow this;
http://www.evotuners.net/forums/show...=1810#post1810
I'm running pretty much stock right now. I'm not anywhere my car but some very conservative setting I put was like around 4000-4500 +1 5000-5200 -3 5200-5600 -5 5600-6000 -7 6000-6400 -9 6400-7000 -9 7200--- +10.
I put +10 after 7200 as a precautionary measure. I'm not sure if it will help prevent detonation after redline, but when my friends drive my car they always misshift.
Bastards...
Bastards...
The logger plugs into the OBDII port and lets you log timing, tps, etc.
It does read the stock narrow band, so you can't really fine tune a/f ratios with it, but it does assure that you are still pig rich (safe).
I was going to get one, then I got confused about what I needed to buy and what was a "good" logger for a good price. I was leaning towards the pocketlogger.
I'm now looking to get my car flashed soon, but a logger could still be useful, right? I'm probably going to sell the SAFCII to fund the flash.
Thoughts or advice on a particular logger and what "exactly" I need to buy?
FB
FB
FB
FB
Pocketlogger is a fine product, but the same thing can be pieced together a little cheaper like this;
The most inexpensive Palm m100 or m500 series you can find,
a hot sync cable (that should come with the Palm),
an interface like a T16-003 (http://www.multiplex-engineering.com/interfaces.htm)
and free software (http://www.evotuners.net/forums/showthread.php?t=421)
Originally Posted by mooreboost
Shouldn't you be using a wideband o2 sensor instead of the stock narrowband?
Even if I had a wideband I'd still use a logger. Just because you have your A/F ratio on target, doesn't mean the ECU isn't holding timing due to a little knock. You need to see the whole picture and loggers allow you to monitor more.
Originally Posted by turbolarry
A logger is always helpful. It tells you exactly what's going on with your car by being able to monitor and log so many parameters, and reads and clears codes. It will tell you if the flash has your car running it's best or not. Log it, and see what's really going on.
Bastards...
Bastards...
