Questions
Questions
Utec is tunned but im only putting 280's to the wheel....is this right? On hight boost I peak at 21psi and hold, my mods include aps intake, 3" turbo back with high flow cat, along with boost controler. Im running version 1.7 on map one, should I tune with map two to get better results.
Custom tune with those mods.. sounds about right.. Depends a bit on your dyno though.. If its a custom tune your not using any particular map.. If your running an out of the box tune, and you dyno'ed the car, I'm surprised you didn't go through and retune it.. If its a default turboXS map with your mods I would strongly suggest getting a custom tune.
you can tune any map to get anything you want. Just depends on you. Check out evospeed.net for a southeast meet in houston. I'll be there and i can check out your utec for ya.
