Where to find...
Old Jan 24, 2005 | 11:03 PM
BSREVOLUTION's Avatar
Where to find...
connection for the map sensor that connects to the utec? luis said it was a wire that comes with desktop computers. dont sure if im explaining myself clearly. thanks
Old Jan 24, 2005 | 11:10 PM
on a side not. i finally got a tuner lite and did some tuning with the new injectors. im having a problem at 3700rpm's. this area always seems to be very lean, and it doesn't matter how much fuel i add. i havn't started the timing map, but i will once i get some feedback from you guys.
one question. if my problem are is load 30% at 3700rpm, i was told to add fuel to this area all away 30%-100%. if i add here, do i not need/have/should add fuel at 10%-30%? thanks
File Type: txt
Old Jan 24, 2005 | 11:12 PM
here is the log...
File Type: zip
