Knock Thresholds
Old Jan 28, 2005 | 10:39 PM
bishiboy's Avatar
Knock Thresholds
Could somebody please post up the default knock threshold values? I changed mine a while ago and would like to have a base of ref (stupid me, didn't write them down).
I increased my sensitivity, retard step and max retard.
I've noted that since I've done my head (polished combustion chambers), I haven't seen a hint of knock, even with the increased sensitivity.
I think I can pump in some more advance.
Old Jan 29, 2005 | 08:36 AM
MalibuJack's Avatar
Actually save your maps, and reflash your UTEC to the 1.7 firmware.. It should restore the stock parameters for everything.. you can then re-enter the important parameters.
Old Jan 29, 2005 | 08:38 AM
MalibuJack's Avatar
Oh and your right, the biggest reason some cars are less detonation prone than others is how clean the combustion chambers are from the castings.. Also the type of valves seems to make a difference too, how odd is that?
Old Jan 29, 2005 | 05:36 PM
bishiboy's Avatar
Thanks, I didn't think of reflashing.
Maybe a "restore to default settings" would be a good addition in future versions.
