Map wiring
Old Feb 3, 2005 | 03:59 PM
tincan's Avatar
Map wiring
Could some post a pic of the connector used for the map sensor?
Also what gauge wire are you using? It looks like the pigtail is 20 awg.
I have access to all kinds of molex supplies at my work. I just want to make sure I got the right connecter configuration. If so I could pin them up with three feet or so of wire and ship to whoever needs it.
Old Feb 3, 2005 | 06:10 PM
dryad001's Avatar
Yup gimme a few minutes to warm up the camera.
Old Feb 3, 2005 | 08:41 PM
MalibuJack's Avatar
Its the same square 4 pin connector that is used by an ATX power supply for the 12v+ supplemental voltage for the motherboard.. If you work with these parts you know exactly what I'm talking about.
Same connector is used for the EGT gauge..
Oh.. BTW, I need 2 pin molex connectors if you have them..
