Utec Olf Background Map
Old Feb 10, 2005 | 02:37 PM
superman105's Avatar
Installed my Utec about 1 month ago and have been running in lean + knock conditions from their Stage 1 map. 20PSI.
after I read most of the post on here about this problem.
I have few questions in my mind.
1) how do I make sure I have the same background map as others that is running the perfect 11.1 A/F ratio per TURBO XS when their fuel colum is set to Zero.
2) I just dont understand how two similar EVO
Basicly stock can be so big of a difference in a/f ration.
{the only thing I have on my car now is a Cat Delete Pipe (where I mount my O2 Sensor) and boost set to 20psi w/utec,}
My car is running basicly 12-12.35 vs Turbo XS 11.1
can someone explain
Old Feb 10, 2005 | 03:29 PM
Widebandphillip's Avatar
it needs to be tuned, you can't use the off the shelf map and go.
Old Feb 10, 2005 | 04:02 PM
yes your right, thanks for your feed back
but my question is not about getting tuned or not.
it more of a comparison.
Old Feb 10, 2005 | 04:05 PM
and further more, you can't even see your background map in the UTEC
Old Feb 11, 2005 | 08:10 AM
Imprezd's Avatar
What octane are you running?
Old Feb 11, 2005 | 08:43 AM
I'm running on 91 octane
Old Feb 11, 2005 | 08:47 AM
Imprezd's Avatar
If you are running 91 octane you will run at a leaner afr. The base map is for 93 octane. You should probably add a good bit of fuel to get your car to a safer afr.
Thanks,
Jermaine
Old Feb 11, 2005 | 09:15 AM
thank you for your post Jermaine,
very interesting 91 to 93 octane will make so big of a difference in AFR.
from 12.35 ~ to 11~ with just 02 octane more
so if I go with 97 octane which one of the 76 gas station sells them
I will be at 8.5 ~ AFR ?
Old Feb 11, 2005 | 09:17 AM
Imprezd's Avatar
It's all dependent on the additives used to make the gas arrive at your octane level.
Old Feb 11, 2005 | 09:23 AM
oh I see.
but why does all of the NEW STOCK Mitsubish Evolution VIII accross USA runs rich from the factory setting disregard of the Octane level ?
Old Feb 11, 2005 | 12:20 PM
where did you mount your 02 sensor?
Old Feb 11, 2005 | 01:03 PM
Imprezd's Avatar
Originally Posted by superman105
oh I see.
Mutiple Fuel Maps.
