UTEC ABC install?
Old Mar 3, 2005 | 10:42 PM
EvoVIIIFL's Avatar
UTEC ABC install?
hey guys i'm questioning my install on the UTEC ABC since I can't control the boost level even when I modify the map. I have the ABC attached and the bleeder screw all the way in. Can anyone take pics of how their ABC is hooked up both to the turbo and then connected with the Y connector and then run to the boost solenoid??? All pics and help greatly appreciate you guys!
Also any advice on how far the screw should be in would greatly be appreciated.. I'm trying to get the stock map to at least run correctly
Old Mar 4, 2005 | 08:44 AM
EvoVIIIFL's Avatar
Aw comon anyone? I just want to confirm a huntch that I have that I might have incorrectly hooked it up.
Old Mar 6, 2005 | 06:17 PM
EvoVIIIFL's Avatar
well thanks goes out once again to MalibuJack... definitely earns the EvoM guru title!
