Purchased UTEC + TXS TBE!!
Old Mar 17, 2005 | 11:28 AM
Airs's Avatar
Hi guys, my UTEC and TBE are scheduled to arrive this coming Wednesday. I am getting the TBE installed on the 28th and doing the UTEC install myself. My question is, once its all installed, can I expect to run the Stage 2 map off the website without any problems? BTW, I am in WA - 92 octane here.
Old Mar 17, 2005 | 12:02 PM
dryad001's Avatar
Do everything yourself, the exhaust is very easy to do. The TXS maps are a good starting point but would never run it without tuning it, on some cars the maps run very lean.
Old Mar 17, 2005 | 12:34 PM
Airs's Avatar
So I should wait to load a map into the utec until I either get it tuned by a shop or get the Tuner Pro?
About the exhaust install, the shop is quoting me $135...I dont feel too comfortable doing it myself, doesn't the radiator need to be pulled?
Old Mar 17, 2005 | 12:41 PM
EVO-genetik's Avatar
if your installing the turboback
radiator does not have to be pulled at all
downpipe is real easy to install
135 is alot for installation
when you can do it yourself in like 2 hours..
my .02 cents
Old Mar 17, 2005 | 12:48 PM
EVOLOVE's Avatar
Def do it yourelf. It's easier than you think.
Old Mar 17, 2005 | 12:52 PM
Airs's Avatar
Looked up a how to on the exh install, looks pretty easy! I think I'll do it myself.
About the UTEC, should I wait to use the Stage 2 map until I get a Tuner Pro?
Old Mar 17, 2005 | 12:53 PM
superman105's Avatar
install on Turboback is fairly simply.
as for the UTEC since every unit runs different A/F ratio
it's really unsafe to use the Stage 2 map with it without a Tuner or WideBand.
if you really have to run the stage 2 map without W/D you can still run it but to put that extra safety margin just to make sure things dont become too lean.
I suggest you lower the Injector flow to 500cc under Open Lop Fuel manu.
by doing that it will give you between 5-10% of margin safty *(notice I didn't say 10% althought 550 to 500 is a 10% drop, Due to every UTEC drives the injectors they same way but outcome may vary)
Old Mar 17, 2005 | 12:59 PM
Airs's Avatar
Time to find a used Tuner Pro!
Old Mar 17, 2005 | 01:11 PM
I have a Turboxs Tunner with Bosch sensor.
that I will be selling in about two weeks if your intersted
Old Mar 17, 2005 | 01:17 PM
Airs's Avatar
Sure, PM me with price
Any downside to using the Zeitronix Wideband instead of tuner pro?
Thanks!
Old Mar 24, 2005 | 10:56 AM
Airs's Avatar
So I got the exhaust and UTEC yesterday (both used). The cat delete pipe has a bung welded on it for wideband o2...the downpipe has no bung. Should I have the one on the cat delete filled and a new bung put in the downpipe?
Old Mar 24, 2005 | 12:35 PM
Airs's Avatar
Well, talked to turboxs, they said it wouldn't make a difference.
Old Mar 24, 2005 | 02:39 PM
PDXEvo's Avatar
Hey Airs,
Nathan from TurboXS will be coming to tune the UTEC at Perfection Motorsports next month here in Hillsboro OR. You should plan on coming down for that!
Perfection Motorsports is finishing up with my car today and I have a TBE, Fuel Pump, and an AVC-R and I am putting out just over 300WHP. They really know how to tune the UTEC there!!
Old Mar 24, 2005 | 03:48 PM
Airs's Avatar
Thanks for the heads up PDXEvo. I would love to come down for a tune. Any idea where to sign up for it?
Old Mar 24, 2005 | 07:19 PM
PDXEvo's Avatar
Give Kelley at Perfection Motorsports a call at: 503.848.2707!
Tell him Chris sent ya!
