ECU + Is anyone using this ??
http://www.ecuplus.com/ I have created a "Factory" Map and a Map so lean I heard
detonation, as well as maps in between the two extremes. I works as well as a SAFC
as well as allowing you to adjust Timing, it takes into account the size of the injectors you have in the car etc...I am just really getting started, but I a very pleased with this product
I've been running this unit for a while now, so far I've put 343 whp @ 22psi on 112 octane (very conservetive tune). This was on a stock turbo, everything else is upgraded. There is a new version coming out which will have very cool features. I'll post up once it is out of the beta stage and into production. Check out the forums for updates ecuplus.com/forums.
DrEvo
DrEvo
Originally Posted by BADEVO
I was looking around at engine management stuff and saw the ECU+ on MACHV. Anyone using it and have good results???
