Newb Question.
Newb Question.
With the Utec, do I need a boost controller or can I set it and change from pump gas boost/map to race fuel boost/map with just the map selector... If so how can I control the boost from the utec?
You don't need a boost controller if you use the ABC that comes with the utec. Yes you can program two different boost maps and switch between them using the map selector. There is a boost table you tweak inside the utec to get your desired boost.
