AMS Water Injection
I`m going to use 100% methanol with WI
What is the max safe boost on 93octane+WI(100%Methanol)?
Because i liked 35psi on Chrisevo video
My Main Mods:
Deck Stroker 2.3
AMS GT35 kit
MOTEC M800
Thanks
My Main Mods:
Deck Stroker 2.3
AMS GT35 kit
MOTEC M800
Thanks
The amount pf boost you can run can be determined by alot of things, mainly tuning. You have to watch your knock levels and timing. Usually Ive seen similat setups boosting at around 29-30. Again be sure to datalog if possible with the motec make adjustments carefully
Originally Posted by timmiii
got any links for this water injectin system? im also interested to know if this is system is reliable or not.
A/f
Originally Posted by Frank Dux
