264/264 cams, stock ecu, and tuning
Old May 2, 2005 | 10:45 AM
d15b7's Avatar
hello guys.
i actually have a hks super afr, but it is really similar to your s-afc, at least in the way it adjusts for fueling, so i thought i'd ask my question here....
my car is very close to stock; i don't have a boost controler, i don't have a ecu flash. i do have a cat delete 2.5" downpipe and a rear muffler delete. i have the hks super afr on there and have tuned the car to 11.3 - 11.5 AFR from 3500 to 7800 using a wideband LM-1.
question as follows: i just bought a set of very slightly used HKS 264/264 cams, which i'd like to install myself. i would then like to retune using just the HKS super AFR, without a flash.... is this piggyback unit going to be able to tune the car well enough to support a good idle, good "regular commuting" around town manners, and a good performance when its mashed to the wood?
the tune currently, without the cams installed, starts at 3500 (-1) and goes to (-12) at the redline.....
thanx, piggy back gurus!
todd
Old May 2, 2005 | 10:51 AM
berkel's Avatar
Should work.
I made 300 WHP with 264i/272e cams and an SAFCII.
I made slight adjustments SOTP (no wideband! ), and idle was fine with a mild lope (no cam gears). With straight 264s should be ok.
Good luck,
FB
Old May 2, 2005 | 10:58 AM
Nesiop's Avatar
For better idle wouldn't you need to adjust your timing through the ECU and timing from the Cam Gears?
Old May 2, 2005 | 12:42 PM
d15b7's Avatar
hi. i didn't get cam gears; was told that with 264/264 they weren't alot of use; with the bigger cams, apparently they are needed alot more.
i think with the hks super afr i can adjust the idle mixture independantly of the power adjustment mixture; also i plan on upping the idle to about 950 to 1000 rpm to smooth it out a bit....
thanx for the responses so far!
Old May 2, 2005 | 01:04 PM
scherejs's Avatar
you don't need the gears. you should have no problems having stock-like idle with straight 264's. if by chance you do just get a mail in flash and then fine tune it with you hks unit and wideband.
