need immediate help! can't get LM-1 to datalog rpm...
hello.
i have an Innovate LM-1 wideband. it works great; only problem is that i have the datalogging LMA-2 module, which i have hooked up to read in the rpm, so that i can make runs and later look at the rpm vs A/F.
i have tried hooking it up directly to the rpm wire signal going to the ecu.
i have tried making a bare wire end and wrapping it around one of the spark plug leads....
no dice, no matter how i have it configured, it reads around 2000 rpm always on the rpm tracing. the red light is on steady when it is hooked up; i have done the calibration both ways; have done it with the computer's sound card, and with the car holding steady at 2000 rpm and hitting the setup button...
can anyone help? i have a major tuning session i need to do tonight!
thanx
todd
d15b7@aol.com
thanx
todd
d15b7@aol.com
Do you have the rpm pickup cable? I wouldn't want to splice ecu tach wires on other customer's cars. If you had to, did you wire into the correct one? Are you actually logging that selection? I think you'd have to configure the voltages compared to rpms aswell. Post on the innovative forum. Klaus would help you out a lot more than i can.
