05 GSR safc settings
hey i have a safc and wondering what settings i should have it at
my mods 3" turboback catless
Hallman MBC 20~21psi
Drop-in K&N
GSC 272/264 cams
walbro pump
what clynder should ui have the car select at
its should be at 4 correct?
so what settings do you guys prefer for hi-throttle
thanks
ej
Drop-in K&N
GSC 272/264 cams
walbro pump
thanks
ej
thanks
thanks
Yes, use 4-cylinder and Karman.
i could probably give you mine! it was tuned by AMS! but all cars are different!
I have similar mods but i would advise you to get it tuned!
nuf said!
at first i thought this was bull being fed by selfish people but later i larned that in fact it was true!
nuf said!
nuf said!
nuf said!
correction.. you cant use anyone elses aggressive settings. If you take the someones general settings with similiar mods.. and richen them up by 4% then there shouldnt really be a leaning out issue. Iv done some looking around and Al, malibu jack and some others recommended adding fuel before 5000rpm. 5000 should be 0 and you can start taking out fuel from there, on my car 2600 rpm will go very lean (13.0) without adding fuel.. you could just tape down from -5 from here and i cant see that being a problem. hi low should be set at 40/60
Do you honestly think you should be giving someone AFC recommendations after running -21 at 7000rpms with stock injectors and not knowing it?
Originally Posted by razorlab
bdking57,
I was not the one that set it up to -21! I knew nothing about it at the time or how it worked, which is why i paid a "proffesional". this is the way a reputable shop on this site set it up for me (which is scary).. i would never set this thing up past -5 or -6 by myself.. currently at -5 after reading almost every post about setting up the safc II for the evo..malibu jacks old posts have been a huge help in figuring an appropriate super safe setup untill i can find a new tuner.
Originally Posted by DCSilvrEvo
Funniest setting ive seen b4. Maybe its because of the injectors?
What part of it is funny?
Originally Posted by 05-EVO-GSR
High
-14
-14
-14
-14
-14
-16
-18
-18
-18
-18
-19
-19
-14
-14
-14
-14
-14
-16
-18
-18
-18
-18
-19
-19
I am running -28 at 7000 and 7400, -22 at 6800
11.3 AFR in midrange dropping to 11.0 past 6500
91 octane
720s
FP
SAFC2
Turboback
no-cat
MBC @ 1.4bar
Find a shop with a dyno, and pay to have it tuned. Get a good baseline, and then get some 'aggressive' settings. Realize though, those more aggressive settings will be greatly affected by air quality and temp, so be prudent when you decided to go from conservative to more aggressive.
However, I can't stress enough, find a shop with a dyno and a wideband 02, and get the car dialed in to a safe but powerful tune.
Have you checked you AFR with thoses? they seem a tad conservative with your mods.
91 octane
720s
FP
SAFC2
Turboback
no-cat
MBC @ 1.4bar
91 octane
720s
FP
SAFC2
Turboback
no-cat
MBC @ 1.4bar
I agree those seem very rich, Have to be in the low 10's or high 9 range. I have mine in the upper RPM range in the high -20's and I am running 10.9 to 11.0 AFR. I also am using 680cc injectors.
