Apexi Boost Controller Settings?
Old May 26, 2005 | 10:25 PM
Greyfox5's Avatar
I just instilled my apexi boost controller and i was trying to read the settings and fine tune it but im having some difficulty, I will admit im not a guru at settings, so if anyone has the apexi boost controller and has some good settings or recomandations it would be greatly appreciated, and yes i did look but i might have missed a thread, is so sorry but thanks for help.
Old May 28, 2005 | 03:28 AM
Greyfox5's Avatar
omg come on, anyone please
Old May 30, 2005 | 07:24 PM
bdking57's Avatar
ok this is what i have mine set at.. set the gear speed to 3 for all. set duty cycle to 60 untill 5000 rpm then taper down to 51 duty cycle. Set boost at 1.4mmhg... strait across untill 6500 rpm and then taper down a notch. oh yeah.. one thing you have to make sure is that your boost sensor is correct. I had mine setup wrong at first and the boost on the gauge was ready way off, however vacumm was correct... i kept trying to match it up with my boost gauge with it set at 1.3 and it kept wanting to boost to 1.6.+
also you will want to mess with the gear specific settings
edit.. ok just checked on mine and the correct sensor is absolute 2. I have the gear specific start dutys at +5 +3 +0 +3 +3.
Old May 31, 2005 | 04:43 PM
Greyfox5's Avatar
thanks again man
Mordeth
22
Jun 13, 2010 06:13 AM
justa4banger
Apr 15, 2008 08:26 AM
NTICEN
Mar 20, 2008 08:55 PM
QAT-R
Aug 15, 2005 05:39 AM
Silver05Bullet
Aug 14, 2005 11:44 AM
