got questions
Old Jul 8, 2005 | 06:27 AM
Derek888's Avatar
got questions
If I get the power FC I just unplug the stock ecu and replace it with the power FC? There are no wires or harnesses that I need to buy or splice correct?
Also what sensors comes with the unit, and the d jetro version?
Old Jul 12, 2005 | 01:22 AM
joegardner's Avatar
hey, I just recently purchased the apexi power fc d-jetro version. There are two sensors that you have to wire. The air temp. sensor and the water temp. sensor. There is a little splicing that needs to be done. And the air temp sensor requires a hole to be drilled in the manifold. I havent installed my power fc yet. So I am going by what the manual says. I might install it tommorrow. I will let you know the fine details when I do. Hope I could help. Joe
