Profec B-spec II question
Old Jul 21, 2005 | 08:02 PM
gixxer9's Avatar
My profec has a weird problem where the alarm will sound before hitting my boost limit. This will go away if I change the alarm setting just one digit in either direction, but I have to do this every time that I start the car. It isn't very hard to do, but it is an inconvenience, and can't be normal, right?
Old Jul 22, 2005 | 04:24 PM
AreSTG's Avatar
not normal, could be a bad connections somehow somewhere? as long as your limiter is set higher than peak boost you should have no problem unless your gain is too high and you are spikeing. how changeing it either direction helps is weird.
Old Jul 23, 2005 | 11:00 AM
gixxer9's Avatar
Exactly what I was thinking, but it's not spiking.. The alarm is set at 250, but will sound at 20 to 21 psi. If I change the alarm after the car is running to anything other than where it was, it works normally... Maybe I should write to GReddy on this...
Old Jul 23, 2005 | 01:09 PM
gixxer9's Avatar
Anyone?
