Will the PFC L-Jetro (2003) work in a 2005?
Old Aug 7, 2005 | 10:05 PM
Karash's Avatar
I am guessing it will...but was not sure if the ACD had anything to do with the ECU, or if there were any major changes to the 2005 ECU over the 2003.
Thanks!
Old Aug 8, 2005 | 06:41 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
Does that mean someone got a new EVO?
Old Aug 8, 2005 | 07:23 PM
Karash's Avatar
LOL yea...that would be me.
I think the pinout chart is the same from a 2003 to a 2005 is that correct? It would be interesting if I plugged in my L-Jetro and see if there is a noticeable difference in performance from the factory. It might need a flash or something like that, which I doubt I could get. But since its the MAF version of the PFC, its basically a 5 minute install (with 20 mins of idle testing).
It sucks being in a slow evo! LOL
Old Aug 16, 2005 | 01:04 PM
Karash's Avatar
Last Bump!
Old Aug 26, 2005 | 02:57 AM
ASTROEVO's Avatar
so did it work/// since you never return my calls?
Old Aug 26, 2005 | 03:57 AM
Karash's Avatar
Yea right, like you call
Old Aug 29, 2005 | 07:23 AM
Karash's Avatar
Well I put in the Power FC, and reset the ECU back to factory default. Let it idle some, and went on some test pulls. With the high heat here (90+ degress at 10pm) and **** poor gas (91 oct with 10% eth blend), the thing was knocking like crazy. Finally got it to calm down with a -5 degree pull in ingition timing across the board. I don't have a wideband so I wasn't going to mess with my injection settings.
-5 degrees is pretty bad...but the car was definately stronger (my friend verified with his butt dyno). If I used 100 octane, I think this car would pick up 20 or 25 hp just by swaping the ECU with factory settings. Pretty impressive.
Old Aug 29, 2005 | 11:25 AM
ASTROEVO's Avatar
Damn JOe..... well congrats I guess..... Sounds like the knock would be attributed to the **** gas... since the PFC comes with a base map that is tuned for 101 octane jap gas.... But at least you dont have to buy a new comp!
Old Aug 29, 2005 | 07:25 PM
Karash's Avatar
Yea true.
I could just get back on the habit of getting 100 octane here at the local station...but 5.50 a gallon sorta sucks (and its going up)
danielsl1999gsx
Sep 7, 2016 08:07 PM
davidmitsusrock
Lancer Engine Management / Tuning Forums
Jun 26, 2009 06:27 PM
MalibuJack
Mar 23, 2007 12:43 PM
jcnel_evo8
33
Jul 23, 2004 05:10 PM
