Harness for Emanage Ultimate
Harness for Emanage Ultimate update
Whats up with the harness to upgrade to the ultimate from the blue? 45.00, thats all it takes to get the ultimate or am I mis understanding?
Sorry, not enough info....heres the rest off of the greddy site: What I'm talking about is in bold....
e-MANAGE ULTIMATE
(Advance Engine Control Unit Manager)
The GReddy e-manage Ultimate was engineered to preserve the best features of the original e-manage (an economical price, the use of existing sensors, the ability to easily alter stock settings, & the vast compatibility for most Japanese performance vehicles), while advancing new innovations in piggyback engine control management. Although the external physical dimensions are the same, the Black-Chrome Ultimate has an increased number of input and output ports along with new built-in adapters, to add a number of new options.
In addition to standard e-manage airflow-based adjustments, the Ultimate version includes new and upgraded features. Included is a PC-based Ultimate Support Tool software CD, with an easy-to-use Parameter Set-up, tab menu format and speedy USB communication. Ultimate has improved direct Map control for adding and subtracting Fuel and Ignition. The ability to switch between 2 preset tuning Maps (i.e. Street or Race program) via externally mounted toggle switches. There are Maps for Individual cylinder adjustment for both Fuel and Ignition. There are also options to convert injection and ignition systems (i.e. group or sequential injection and group or individual fire ignition.) An Airflow Output Map option even allows for airflow meter elimination. And when used with a wideband A/F Meter, the Air Fuel Target Map can self-tune an Injector base tuning Map, to speed up initial tuning. There are also built-in Boost, Rev and Speed Limiter-Cut features. To create super smooth operation, there are various fine tuning Correction Maps to adjust for Throttle Acceleration, Vehicle Speed, Water Temp, Intake Temp, Auto Trans Shift, Anti Engine Stall, and Idle. To further aid in tuning, e-manage Ultimate's improved integrated Monitoring, Map Tracing and Datalogging features far exceed any other piggyback controller on the market. Even when not connected to the software, 8 channels of datalogging (at 20msec intervals) can be recorded and stored to be reviewed later. With the Support Tool connected, over 30 channels can be covered. Other new features include: Improved RPM recognition, Warning Settings, Password Protection for individual tuning Maps, NVCS (Nissan), VTEC (Honda), O2 Feed-back, Clean Fouled Plugs, and numerous others in future updates.
Ideal for optimizing and fine-tuning for performance products like Exhaust, Air Intake, Intercoolers, Boost Controllers, and Turbochargers, the e-manage Ultimate fills the gaps between conventional piggyback and expensive stand-alone engine managements.
All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some or all functions may not be compatible with some applications.)
E-MANAGE ULTIMATE
DESCRIPTION SPL NOTES PART# LIST$
E-MANAGE ULTIMATE advance piggy-back ECMU w/ CD Software 15500501 $680.00
ULTIMATE HARNESS KIT complete wiring harness 18.14, & 12pin 15901500 $120.00
ULTIMATE SUPPLEMENT HARNESS use to upgrade from emanage to Ultimate, 14Pin 15901501 $45.00
e-MANAGE ULTIMATE
E-MANAGE ULTIMATE
