UTEC pulled timing?
Old Aug 13, 2005 | 09:56 PM
IS2000's Avatar
UTEC pulled timing?
I just recently filled up with 100 octane (the car had 110 before and was running 1.8kg/cm of boost on a different map). I turned the boost down on my MBC, switched to 100 octane map and went for a test run. The boost still spiked to 1.7kg/cm and I could feel a slight power loss right away with boost dropping to 1.4 . I was just wondering if that was UTEC retarding the timing?
Thanks
Old Aug 13, 2005 | 10:01 PM
SlowCar's Avatar
just do a data log, u will see what is going on
Old Aug 13, 2005 | 10:06 PM
SlowCar's Avatar
also, the SES light will blink if you are knocking when you are in maps other than 0/ecu
Old Aug 13, 2005 | 11:20 PM
IS2000's Avatar
I don't have a laptop to pull a data log now, but I'll try to do it later. I didn't notice the CEL blinking, because I was looking at the boost gauge at the time. The car did the same thing when I had a reflash and hit a boost spike.
Old Aug 15, 2005 | 07:31 PM
IS2000's Avatar
BTW, can I still pull the old log after I did a couple more runs?
Old Aug 16, 2005 | 05:45 AM
EvoTech's Avatar
Nope. You need to log it as it happens.
