Cams = more rich than before?
Old Aug 14, 2005 | 01:26 PM
fuzzychi's Avatar
Well I just did a log of my o2 readings (narrowband) and the voltages from 3.5k - 7k are all reading around .96-.98v, meaning that I'm definitely running rich throughout most of the powerband. Is this right? I thought by adding in the cams the car would naturally have more air coming in and shouldn't be as rich as this....unless before the cams the car was even running more rich than it currently is. The settings on my AFC before were from Buschur on their generic conservative tune. Any thoughts about my situation? Any help or insight would be appreciated. Thanks.
Old Aug 14, 2005 | 02:40 PM
kmcconn9's Avatar
you definatly need to get the car tuned after you get the cams installed..it will make a big difference...both buschur and al would agree
Old Aug 14, 2005 | 06:30 PM
taenaive's Avatar
more air means more fuel will be delivered. less air mean less fuel. and stock ECU map will try to give you rich if you suck in more air. And .96v is okay and safe. when your engine gets really hot, that number will become .92v or below.
Old Aug 14, 2005 | 06:31 PM
fuzzychi's Avatar
Well I am thinking of road tuning my Evo with a datalogger.
Old Aug 14, 2005 | 06:35 PM
fuzzychi's Avatar
Should I lean it out? Or just leave it
Old Aug 14, 2005 | 06:43 PM
BoostWhore's Avatar
I wouldnt do anything without a wideband if u have one then tune away
Old Aug 14, 2005 | 06:44 PM
taenaive's Avatar
I would eliminate .98v
Old Aug 14, 2005 | 07:00 PM
kilo_dave's Avatar
+1 kajillion, get a wideband, they're cheap now.
Old Aug 14, 2005 | 07:45 PM
fuzzychi's Avatar
Could I even get close for now with pocketlogger and narrowband? I dont have enough money for $300 wideband right now. I know Warralton uses just S-AFC and pocketlogger for his tuning.
Old Aug 15, 2005 | 12:26 AM
fuzzychi's Avatar
Old Aug 16, 2005 | 04:42 PM
fuzzychi's Avatar
Old Aug 16, 2005 | 06:22 PM
sayanara's Avatar
yo fuzzy, someone told me that you can pick up a aem uego for cheap from jegs. Isn't there a jegs in cbus somewhere.
Old Aug 16, 2005 | 06:23 PM
fuzzychi's Avatar
Yea, I think like $260 for the UEGO but.... I am kinda broke right now lol.
