Bah I knew it would happen lol .. I installed the SAFC-II last night (took like 3 min lol), and did all the initial settings ... Karman, 4 cyl, arrow pointing to upper right etc...
I didnt change any values in the fuel settings .. yet ... when I'm accelerating (not even wot), in 1st gear my boost jumps and I hit fuel/boost cut quickly around 2500-3500 rpm ... I immediatley let off and took it out ...
I dunno if I wired it wrong or anything since it was all prewired ... I feel like I got to resolder it anyway ...
Its off the car right now and everything is normal .. Yeah I suck I know lol ..
Ideas?
According to our tuning god Dr. Gray via his FAQ :
3. Common Problems:
RPM Signal off by half (1G)
* Because of the way that Mitsubishi triggers the ignition coils, this is normal. To fix it, just set the Cylinders to "2"
Car runs like crap, wont rev past 2-3K rpm, No change in the Hz reading on the Karman display
* You read the wrong section in the manual and chose the yellow and white wires to modify the airflow signal. Wrong, you should have used the pink and orange wires.
* You have a bad connection on either the pink or orange wire.
* You have the pink and orange wires reversed.
* You didn't select "Karman" for the air flow meter type.
I'm already using the Pink and Orange wires ... So if anyone who had this problem just resolder or ? And yes I did haev Karman set for Air Flow Type ...
Input? I'm running stock injectors/fuelpump - but everything was set @ 0% no changes to the settings @ all .. not even throttle points ..
Ideas?
3. Common Problems:
