help with safc install
Old Sep 10, 2005 | 08:50 PM
lockjaw's Avatar
just got a a safcII and help with ecu wiring install. please help.
thanks
paulie
Old Sep 10, 2005 | 09:58 PM
Warrtalon's Avatar
You typically figure this stuff out BEFORE making the purchase.
Go to Evotuners.net and look in the Tech Guide underneath ECU/Tuning. That will provide you all the info you need...
Old Sep 10, 2005 | 10:02 PM
Spec'd's Avatar
thanks
paulie
Boomslang makes a plug-n-play wiring harness, if you don't mind spending
another $120.00. At least you can avoid splicing into your factory ECU wiring.
If you don't know what your doing with that SAFCII, learn before you burn...
up your motor that is.
Old Sep 10, 2005 | 10:13 PM
lockjaw's Avatar
i got the harness cause i didnt want to splice into the ecu. thanks for the help.
and i know how to tune it i just wasnt sure about the wiring.
Old Sep 10, 2005 | 10:16 PM
Spec'd's Avatar
Oh allright, I see that's cool, did you find the Boomslang ?
Old Sep 10, 2005 | 10:31 PM
lockjaw's Avatar
yeah i seen the boomslang but i actually bought this from a friend that bought it from lancer shop with their harness and then his car got totalled. so i wanted to help him out and bought it from him. the harness kinda sucks though, not color matched. but what can you do. and for $220 for the safc and harness i couldnt beat it. just make my job alittle harder but its cool, i dont mind. thanks for the help though
Old Sep 10, 2005 | 10:41 PM
Spec'd's Avatar
As long as it works. It sounds like a good deal.
I've been thinking about the SAFCII or WORKS P2 Flash.
I don't know we'll see.
