Tuning for 100% Methanol Injection
Old Sep 12, 2005 | 01:44 AM
joeymia's Avatar
Should I shoot for more boost or higher timing and AFR? What would be some good target AFR from 4k to the redline? I am still using the stock Turbo and no 10.5 hotside.
Old Sep 12, 2005 | 04:48 AM
MalibuJack's Avatar
I wouldn't alter the AFR much, but you can tune more timing and higher boost... I would tune for boost first, then alter timing a bit Alky tuning is best done on the dyno though...
Old Sep 12, 2005 | 04:24 PM
EvoTech's Avatar
You should always leave yourself a bit of safety on the rich side for meth injection. I would target 11.0:1. That is what I did running 100% meth. Still made great power. If you ever has the meth fail, you better be running a tad rich if you have any chance of saving it.
Old Sep 12, 2005 | 07:28 PM
joeymia's Avatar
= meth injection
I am making awesome power. I want to dyno this thing now I am thinking i am sitting at 350/350+ on a dynojet.
Old Sep 12, 2005 | 07:33 PM
Evoryder's Avatar
torque is never the same on our cars once we start tuning...
Old Sep 12, 2005 | 08:53 PM
joeymia's Avatar
I have a problem when comming up to the redline where the car seems to run out of fuel. It bucks big time. If i run at like 24psi I get the bucking once I get to around 6k. At 21 PSI it'll sometime starting buck at 7k. Do I need to upgrade injectors? My injector duty cycle is not 100% but it feels like it has no fuel. I was running really rich since I was still testing the Methanol.
here are some logs:
Code:
4001	24.9	965	80	10	0	11.4	45.7	ECU. 	6	ECU.  	1190
4120	25.1	1262	100	20	0	9.8	64.9	5.9	6	ECU.  	1207
4301	25.1	1483	100	40	0	9.8	77.8	6.8	7	ECU.  	1623
4450	25.3	1436	100	60	0	10	72.4	7.5	7	ECU.  	1572
4623	25.3	1510	100	70	0	10.3	74.7	8.2	7	ECU.  	1633
4775	25.3	1552	100	80	0	10.1	73.8	8.6	5	ECU.  	1633
4909	25.1	1572	100	80	0	10.3	75	9	5	ECU.  	1592
5042	25.1	1612	100	80	0	10.3	77.4	9.4	4	ECU.  	1666
5175	25.1	1633	100	80	0	10.2	78.1	10.1	1	ECU.  	1724
5350	25.1	1655	100	90	0	10.3	77.6	10.6	0	ECU.  	1736
5509	25.1	1736	100	90	0	10.5	80.7	11.1	0	ECU.  	1736
5630	25.3	1779	100	90	0	10.4	80.7	11.4	-1.2	ECU.  	1798
5797	25.1	1838	100	100	0	10.3	79	11.9	-2	ECU.  	1700
5941	25.1	1858	100	100	0	10.6	80.6	12.2	-2	ECU.  	1811
6082	25.1	1872	100	100	0	10.7	80.6	13.2	-2.4	ECU.  	1865
6207	25.1	1915	100	100	0	10.7	80.8	14.4	-3.6	ECU.  	1838
6337	25.1	1930	100	100	0	10.7	80.9	15.8	-4	ECU.  	1851
6472	24.9	1953	100	100	0	10.7	81.4	17.2	-4	ECU.  	1923
6613	24.9	1984	100	100	0	10.7	82.5	18.3	-4	ECU.  	1798
6720	24.7	1984	100	100	0	10.7	83.3	19.2	-4	ECU.  	1923
6844	24.9	1984	100	100	0	10.7	83.8	20.4	-4	ECU.  	1838
6958	24.9	2000	100	100	0	10.7	84.4	21.9	-4	ECU.  	1851
7107	24.9	2000	100	100	0	10.6	84.6	22.2	-4	ECU.  	1908
7215	24.9	2024	100	100	0	10.7	85	22.1	-4	ECU.  	1773
Code:
2267	25.3	111	13	0	0	12.8	5	ECU. 	0	ECU.  	111
2856	25.1	113	13	0	0	14.5	5.3	ECU. 	0	ECU.  	110
3531	25.1	113	13	0	0	14.4	5	ECU. 	0	ECU.  	110
4268	25.1	113	13	0	0	13.1	6.4	ECU. 	0	ECU.  	112
4486	25.1	117	13	0	0	13.9	6.7	ECU. 	0	ECU.  	119
4450	25.1	115	13	0	0	14.7	5.9	ECU. 	0	ECU.  	120
4468	25.1	279	22	0	0	16	12.6	ECU. 	0	ECU.  	292
4426	25.1	324	25	0	0	16.9	13	ECU. 	0	ECU.  	320
4474	24.9	407	27	0	0	13	17.3	ECU. 	0	ECU.  	476
4610	25.1	651	44	10	0	12.8	30.7	ECU. 	6	ECU.  	781
4662	24.9	897	65	10	0	10.9	41.4	ECU. 	6	ECU.  	919
4775	24.7	1179	79	10	0	10.1	62.1	ECU. 	6	ECU.  	1420
4789	24.7	1587	100	30	0	9.9	82.8	7.5	7	ECU.  	1712
4880	24.9	1754	100	60	0	9.7	87.7	8.5	7	ECU.  	1724
4997	25.1	1672	100	70	0	9.8	83.2	9.2	6.3	ECU.  	1785
5208	25.3	1742	100	90	0	10.3	81.2	10.1	0.6	ECU.  	1893
5359	25.5	1792	100	100	0	10.4	81.5	10.7	0	ECU.  	1798
5509	25.3	1818	100	100	0	10.5	81.2	11.1	-0.2	ECU.  	1773
5649	25.3	1851	100	100	0	10.6	81.4	11.5	-1.4	ECU.  	1724
5807	25.3	1893	100	100	0	10.5	81.7	12	-2	ECU.  	1798
5952	25.3	1923	100	100	0	10.7	82.3	12.4	-2	ECU.  	1908
6093	25.3	1968	100	100	0	10.6	83.4	13.4	-3	ECU.  	1893
6242	25.3	1984	100	100	0	10.6	83.7	14.9	-3.8	ECU.  	1824
6361	25.1	2008	100	100	0	10.7	84.3	16	-4	ECU.  	1923
6485	25.1	2032	100	100	0	10.7	85.9	17.2	-4	ECU.  	1908
6640	24.9	2049	100	100	0	10.7	84.4	16.7	-4	ECU.  	1923
6915	24.9	2057	100	100	0	10.3	85.8	18.3	-4	ECU.  	1851
6802	24.7	2074	100	100	0	177.3	86.4	19.7	-4	ECU.  	1923
6915	24.9	2066	100	100	0	10.6	86.7	21.1	-4	ECU.  	1838
7032	25.1	2066	100	100	0	10.6	85.8	22	-4	ECU.  	1865
6802	25.1	1524	100	100	0	24.2	66.6	21.9	-4	ECU.  	1470
7062	25.3	2040	100	100	0	10.3	84.6	21.4	-4	ECU.  	1908
Any help would really be wonderful.
Old Sep 12, 2005 | 10:17 PM
geminibby's Avatar
do you think you still have the fuel cut enabled? I'm far from being an expert, but it doesn't seem that youre hitting high inj duty cycle so you still have room there. if you are bucking at 6k@24psi, sounds like you might be hitting fuel cut especially if you when you lower the boost and its further up the rpms.
Old Sep 12, 2005 | 10:25 PM
joeymia's Avatar
i thought the utec eliminated the fuel cut...
Old Sep 12, 2005 | 10:29 PM
geminibby's Avatar
it depends on which version you have. i think the most recent filmware is 1.7, but i could be wrong. check out turboxs.com and see what the newest is. i had a similar problem when i installed my cams which was before the new filmware and on a cool morning i would get on it in 3rd and it would hit fuel cut at about 5k. afterwards, got the new version and didnt have anymore problems since.
Old Sep 12, 2005 | 10:35 PM
joeymia's Avatar
Ahh just read the manual saw the options under the Open Loop Fueling section. I thought UTEC totally removed the fuel cut. Still figuring this out hehe.... So what would be a good setting for the MAF Overboost fuel setting? Should I just max it out to 30?
Old Sep 13, 2005 | 06:57 AM
dryad001's Avatar
No, set it at 21. Go up slowly if you need to go up, it's there ofr a reason.
Old Sep 13, 2005 | 07:04 AM
dsm95hybrid's Avatar
Your problem is likely ignition related, not injector related.
Leaning AFR has netted the best power for me. Stock timing numbers. No knock even to 12.7a/f. Even hit 28* timing at 8000+ rpms.
Do not attempt this without monitoring afr, and timing on every run as I do.
Timing hold or retard will indicate a lean condition and/or knock presence. Reduce boost or richen a/f at that point.
Old Sep 13, 2005 | 08:17 AM
MalibuJack's Avatar
The reason you don't run that lean is EGT's and very little headroom for detonation.. I've also run that lean on occasion, but you can't run that for more than a few seconds at a time (Quarter mile run) since I do high speed runs and road racing type stuff, I only tune like that for glory runs..
I can tell you know that 28 degrees of timing is probably innacurate.. Your either experiencing knock and removing that 8 degrees, or your stock ignition coils are "Very latent" I discovered (I was running 23 degrees) of timing and had to back it off 2 degrees after I upgraded to the HKS DLI2..
This is assuming your using pump.. Its a different story with 93/Meth or C16 since I can get 27 degrees with C16.. But I don't run C16 so its pointless for me to tune my car like that.
Old Sep 13, 2005 | 08:20 AM
MalibuJack's Avatar
Okay.. The UTEC with open loop fueling does indeed completely override the factory fuel cut, RPM limits, and Boost cut.. HOWEVER it has its own limiters that you can adjust (Thats where your hitting the cut)
I set mine for 2200hz (22) You should log your data and look at your peak maf reading, and set it 10% Higher..
If you have a MAP sensor, you should set that to your max boost you might ever see..
RPM limiter is your discretion, but don't set it over 7800 if you don't have head studs (7800 will probably touch 8000rpm)
Old Sep 13, 2005 | 08:34 AM
For one, we are discussing AFR's not EGT's. #2, This is the "tuning for 100% methanol" thread so of course we are discussing "tuning for 100% methanol". Neither of your claims are correct. I am running full timing, no knock and no retard. In fact I have room for 1-4* of additional timing that I have not modified yet. I would probably choose to go richer at first when adding timing and then lean myself out again after that. Ignition is fine, plugs are indexed and no misfires using 30psi peak and .026 gaps.
Here are timing numbers on a 1-5th gear run.
When using 1-4th gear to 8600rpms timing numbers are higher in 4th. I purposely short shifted this run below to allow for higher boost, but when 4th is wound out timing hits 27-28*.
4400-7
5100-11
6000-15
6792-20
5400 11
5800-14
6300-16
6700-20
7100-21
5400-8
5900-8
6020-11
6200-14
6500-17
6700-19
6900-20
7500-24
8017-27
5900-8
5590-10
5792-11
5942-12
6000-13
6200-14
6300-15
6400-17
6500-18
6600-18
6792-18
6894-20
7000-20
5560-9
5630-10
5742-11
5824-11
5980-12
6020-13
6120-13
6191-14
end
