Hesitation when I go WOT
Old Sep 14, 2005 | 04:41 PM
joeymia's Avatar
I have spent hours tring to figure out why I get hestiation when I go WOT. No matter what I do my car hesitates when I floor it. When I select Map0 my car runs fine. I have logged about 15 minutes of driving using my conservative methanol map. Someone please take a look and let me know if something is odd. I am starting to think my UTEC unit may be defective... BTW I get the hestiation even with the StageI and StageII maps provided by UTEC. In the following logs I can no longer go past around 5k at WOT on Map0 because of the stock fuel cut.
Someone please help!!!
EDIT: 2 of log files had the wrong names.
File Type: zip
Old Sep 14, 2005 | 06:08 PM
MalibuJack's Avatar
The hesitation is probably the transition point your hitting.. I'll have to look at it later though.
Old Sep 14, 2005 | 06:58 PM
EvoTech's Avatar
I cannot make sense out of that log. Can you find a clearer way to post it. Maybe from wordpad.
Old Sep 14, 2005 | 08:04 PM
joeymia's Avatar
they can be opened with excel.
Old Sep 15, 2005 | 08:03 PM
ecmotorsports's Avatar
In my 05 i have the same problem, it was tuned by Turbo XS and they said the cars computer is pulling back boost when it realizes somthing is wrong. Dyno chart looks like i failed a lie detector test. not sure if its the same hesitation that your talkin about, could be a timing problem?
Old Sep 15, 2005 | 08:11 PM
EvoTech's Avatar
These logs are not making any sence. I can not tell what is what. Something seems wrong with these logs. Do you have a tuner and AFR's?
Old Sep 15, 2005 | 08:46 PM
joeymia's Avatar
What program are you using to open the logs? They look fine in excel. The logs were generated with MPS UTEC Logger using a LM1 Wideband.
I am starting to think that something may be wrong with my unit. I have tried so many different things and I still get hesitation. It seems to happen right when UTEC takes control of the AFR/Timing. Like I would be cruising with the TPS at 10% and right when I get around 35% (I think thats when Open Loop starts) the car hesitates like I am getting a fuel cut. Even if slowly accelerate I get the hesitation. I have emailed TurboXS but have not received a response. I guess tomorrow I give them a call. BTW the car runs fine using map0!!! The only problem with map0 is with all the mods I have if i go WOT i hit fuel cut around 5.5k rpm.
Old Sep 15, 2005 | 08:49 PM
joeymia's Avatar
Oh and when I first got UTEC about a month ago I tried using their staged maps. They would do the same damn thing!! I kept on using map0 so I could log and I was not really ready to mess with tuning the thing myself at that time.
Old Sep 15, 2005 | 08:59 PM
EvoTech's Avatar
OK The logs look fine? Why hasn't anyone else chimed in on your logs? Because they make no sense. I would love to help but I can not decifer what I am looking at. And yes I am opening them in excel.
Old Sep 15, 2005 | 09:03 PM
drtalon's Avatar
I know this is going to sound stupid, but try re-gapping your spark plug a little smaller. If the gap is to wide the force of the high pressure air coming into the combustion chamber will acually "blow out" the spark sometimes. It may fix the problem. If not you didn't waste alot of time or effort on it... and it could be as simple as that.
Old Sep 16, 2005 | 07:33 AM
MalibuJack's Avatar
Ya know what.. I just noticed you have a meth kit.. It sounds like it may be kicking in at a particular boost level and quenching ignition for a moment.. Also like the previous post said, check your plug gap, though a misfire would be evident around 5000rpm as a stumble..
Old Sep 18, 2005 | 05:55 PM
joeymia's Avatar
I noticed that everytime UTEC takes control over timing from the stock ECU my car seems to hesitate. Feels like a misfire... Has anyone encountered something like this before? I have the AFR at the same exact levels as the stock when the transition from the stock ECU and UTEC takes place so I have no idea what else it could be. Here is the timing from my map:
Code:
Timing Map
   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]   [-100]
   [-100]   [17.2]   [15.2]   [13.2]   [12.2]   [10.7]   [10.7]   [10.7]   [10.7]   [10.7]   [10.7]
   [-100]   [16.8]   [13.8]   [11.8]   [10.8]    [9.3]    [9.3]    [9.3]    [9.3]    [9.3]    [9.3]
   [-100]   [15.8]   [12.8]   [10.8]    [9.8]    [8.3]    [8.3]    [8.3]    [8.3]    [8.3]    [8.3]
   [-100]   [14.8]   [11.8]    [9.8]    [8.8]    [7.3]    [7.3]    [7.3]    [7.3]    [7.3]    [7.3]
   [-100]   [14.8]   [12.8]   [10.8]    [9.8]    [8.3]    [8.3]    [8.3]    [8.3]    [8.3]    [8.3]
   [-100]   [13.8]   [11.8]    [9.8]    [8.8]    [7.3]    [7.3]    [7.3]    [7.3]    [7.3]    [7.3]
   [-100]   [12.8]   [10.8]    [8.8]    [7.8]    [6.3]    [6.3]    [6.3]    [6.3]    [6.3]    [6.3]
   [-100]   [12.8]    [9.8]    [8.8]    [7.8]    [6.3]    [6.3]    [5.8]    [5.8]    [5.8]    [5.8]
   [-100]   [12.6]    [9.6]    [8.6]    [7.6]    [6.1]    [5.7]    [4.9]    [4.9]    [4.9]    [4.9]
   [-100]   [13.1]   [11.1]   [10.1]    [9.1]    [7.6]    [7.1]    [5.8]    [5.8]    [5.8]    [5.8]
   [-100]   [13.2]   [11.2]   [10.2]    [9.2]    [7.7]    [7.2]    [6.2]    [6.2]    [6.2]    [6.2]
   [-100]   [12.5]   [10.5]    [9.5]    [8.5]      [7]      [7]    [6.3]    [6.3]    [6.3]    [6.3]
   [-100]   [12.7]   [10.7]    [9.7]    [8.7]    [7.2]    [7.2]    [7.2]    [7.2]    [7.2]    [7.2]
   [-100]      [9]    [7.5]    [7.5]    [7.5]    [7.5]    [7.5]    [7.5]    [7.5]    [7.5]    [7.5]
   [-100]    [9.7]    [8.2]    [8.2]    [8.2]    [8.2]    [8.2]    [8.2]    [8.2]    [8.2]    [8.2]
   [-100]    [9.8]    [9.9]     [10]     [10]   [10.1]   [10.2]   [10.3]   [10.3]   [10.4]   [10.5]
   [-100]   [11.7]   [11.7]   [11.6]   [11.6]   [11.5]   [11.5]   [11.4]   [11.4]   [11.3]   [11.3]
   [-100]   [12.3]   [12.4]   [12.5]   [12.5]   [12.6]   [12.7]   [12.8]   [12.8]   [12.9]     [13]
   [-100]   [13.9]   [14.1]   [14.4]   [14.6]   [14.8]   [15.1]   [15.3]   [15.5]   [15.8]     [16]
   [-100]   [15.7]     [16]   [16.2]   [16.5]   [16.7]     [17]   [17.2]   [17.5]   [17.7]     [18]
   [-100]   [16.2]   [16.6]     [17]   [17.5]   [17.9]   [18.3]   [18.7]   [19.2]   [19.6]     [20]
   [-100]   [16.5]     [17]   [17.5]     [18]   [18.5]     [19]   [19.5]     [20]   [20.5]     [21]
   [-100]   [17.6]     [18]   [18.4]   [18.7]   [19.1]   [19.5]   [19.9]   [20.2]   [20.6]     [21]
   [-100]   [17.8]   [18.3]   [18.7]   [19.2]   [19.7]   [20.1]   [20.6]   [21.1]   [21.5]     [22]
   [-100]   [18.5]   [18.5]   [18.5]   [18.5]   [18.5]   [18.5]   [18.5]   [18.5]   [18.5]   [18.5]
   [-100]   [20.8]   [20.8]   [20.8]   [20.8]   [20.8]   [20.8]   [20.8]   [20.8]   [20.8]   [20.8]
I called TurboXS on friday and they told me to just reflash my UTEC which I did. Any other thoughts?
Old Sep 18, 2005 | 07:37 PM
MalibuJack's Avatar
Yes, I usually get around it by setting the 10% column to ECU and removing some of the timing cells and setting them to ECU at lower RPM, then I log the transition and see what the timing is where it hiccups, and smooth the timing between what the ECU wants and the UTEC uses..
Old Sep 18, 2005 | 07:54 PM
joeymia's Avatar
Ok thanks for the TIP I am going to go work on this now
Old Sep 28, 2005 | 09:42 PM
joeymia's Avatar
Well I was logging since I got a new actuator. I wanted to know what you guys think of my tuning progress. This is my everyday street map. This pull was done on 4th gear all the way up to the redline. Ignore the boost taper I am working on getting that fixed
Code:
RPM	PSI	MAF	TPS	Load	Knock	AFR	Ing	Timing	Mod Maf
2262	1.8	321	100	10	0	11.8	13.5	ECU. 	280
2284	2.3	325	100	10	0	11.6	13.8	ECU. 	273
2302	2.7	332	100	10	0	11.6	14.2	ECU. 	369
2344	3	346	100	10	0	11.7	14.7	ECU. 	299
2375	3.4	348	100	10	0	11.8	15.1	ECU. 	374
2422	3.5	362	100	10	0	11.8	15.4	ECU. 	356
2469	3.7	376	100	10	0	11.8	15.7	ECU. 	337
2495	3.9	376	100	10	0	11.9	16.4	ECU. 	388
2538	4	389	100	10	0	11.9	16.9	ECU. 	427
2575	4.2	401	100	10	0	11.9	17.7	ECU. 	403
2624	4.4	437	100	10	0	11.9	18.3	ECU. 	346
2645	4.7	431	100	10	0	11.8	19.4	ECU. 	478
2712	4.9	455	100	10	0	11.7	19.6	ECU. 	523
2730	5.2	466	100	10	0	12	20.5	ECU. 	497
2780	5.5	514	100	10	0	11.9	21.5	14.5	509
2832	6	519	100	10	0	11.8	22.7	14.4	457
2873	6.4	554	100	10	0	11.7	23.6	14.3	456
2955	6.9	576	100	10	0	11.8	24.4	14.2	708
3019	7.2	631	100	10	0	11.9	25.7	14.1	735
3063	7.7	662	100	10	0	12	27.5	14	769
3095	8.4	664	100	10	0	12	28.6	13.9	580
3162	9.1	694	100	10	0	12.1	30.6	13.8	584
3229	9.6	777	100	10	0	12.2	33.6	13.7	889
3290	10.4	811	100	10	0	12	35.2	13.5	819
3367	11.2	871	100	20	0	11.9	37.5	10.6	976
3436	12.1	917	100	20	0	11.9	40.2	10.4	936
3505	13.1	990	100	30	0	12	44.1	9.1	1141
3584	13.9	1061	100	30	0	12	52.2	9	1012
3663	14.9	1131	100	40	0	10.4	55.3	7.7	1256
3741	16	1170	100	40	0	10.6	57.7	7.7	1126
3813	17	1282	100	50	0	10.7	60.2	6.4	1282
3907	18	1326	100	50	0	10.5	65.8	7	1152
3982	19	1449	100	60	0	10.5	67.9	6.9	1533
4074	19.8	1404	100	60	0	10.5	69.8	7.1	1366
4145	20.5	1557	100	70	0	10.4	72.7	6.9	1623
4235	21	1587	100	70	0	10.3	70.3	6.9	1736
4345	21.2	1519	100	80	0	10.6	70.6	10.1	1497
4432	21.3	1529	100	80	0	10.7	70.8	10.5	1633
4516	21.3	1587	100	80	0	10.8	72.1	10.7	1644
4604	21.2	1612	100	80	0	10.6	74.4	11	1644
4694	21	1607	100	80	0	10.5	74.2	11.4	1552
4748	20.8	1639	100	90	0	10.6	74	12	1712
4852	20.7	1661	100	90	0	10.6	75.9	12.4	1655
4930	20.3	1666	100	90	0	10.5	75.5	12.6	1623
5035	20.2	1677	100	90	0	10.5	79.6	13	1677
5128	20	1718	100	90	0	10.5	77.7	13.2	1655
5184	19.6	1712	100	100	0	10.6	79.3	14.1	1748
5265	19.5	1748	100	100	0	10.5	79.3	14.4	1773
5341	19.3	1773	100	100	0	10.6	76.6	14.7	1712
5420	19.1	1818	100	100	0	10.8	78.8	15.1	1824
5500	19	1831	100	100	0	10.8	78.6	15.5	1677
5574	18.8	1805	100	100	0	10.8	78.4	15.7	1773
5649	18.5	1831	100	100	0	10.8	79.3	16	1798
5727	18.3	1838	96	100	0	10.8	79.6	16.4	1689
5787	18	1858	81	100	0	10.7	80.1	16.6	1773
5858	17.8	1865	70	100	0	10.8	79.3	16.8	1748
5931	17.6	1901	88	100	0	10.9	80.4	17.2	1785
6016	17.6	1872	65	100	0	10.8	79.8	17.5	1785
6060	17.5	1893	68	100	0	10.9	80.1	17.9	1798
6127	17.3	1937	94	100	0	10.9	81.5	18.4	1724
6207	17.1	1930	100	100	0	10.9	80.8	18.5	1785
6277	17.1	1945	100	100	0	10.8	81.7	19.1	1851
6337	17	1992	100	100	0	10.8	81.9	19.3	1908
6397	16.8	1953	100	100	0	10.9	81.6	19.5	1748
6447	16.6	1945	100	100	0	10.9	81.7	19.8	1851
6510	16.5	1953	100	100	0	10.9	82.4	20	1893
6574	16.1	1960	100	100	0	10.9	81.7	20	1824
6626	16	1976	100	100	0	10.9	82	20.1	1838
6680	15.8	1953	100	100	0	10.9	81.6	20.1	1865
6734	15.6	1953	100	100	0	10.9	81.8	20.1	1811
6761	15.4	1968	100	100	0	10.9	81.2	20.2	1838
6844	15.3	1960	100	100	0	10.9	82	20.2	1893
6901	15.1	1960	100	100	0	10.9	81.7	20.3	1893
6944	14.9	2000	100	100	0	10.9	82.9	20.3	1879
6988	14.9	1976	100	100	0	10.8	82.8	20.3	1798
7032	14.8	2000	100	100	0	10.7	84	20.4	1811
7077	14.8	1992	100	100	0	10.8	84	20.4	1785
7122	14.8	2016	100	100	0	10.7	83.9	20.5	1851
7168	14.6	1992	100	100	0	10.7	85.1	20.5	1851
7230	14.6	2016	100	100	0	10.7	85.2	20.5	1879
7278	14.6	2032	100	100	0	10.8	84.8	20.7	1838
7293	14.4	2040	100	100	0	10.7	84.8	21	1908
7342	14.4	2024	100	100	0	10.7	84.5	21.1	1851
7407	14.3	2040	100	100	0	10.7	85	21.3	1879
7423	14.3	2049	100	100	0	10.7	85.7	21.4	1893
7457	14.3	2032	100	100	0	10.7	85.1	21.7	1879
7490	14.3	2066	100	100	0	10.7	86.1	21.7	1923
7490	14.3	434	76	100	0	10.7	16.3	21.1	181
