Installed a wideband...14:1 AFR wtf?
Old Nov 3, 2005 | 09:42 PM
4TUN8's Avatar
Is there something that I'm not doing? I installed the AEM UEGO gauge type, connected it to the ECU+ it reads everything and is pretty close to what the gauge is saying.
That being said, my initial run was like 14-15AFR from 5k-redline. I tried adding some fuel, got it down a little bit, then I added +18 fuel and my laptop died so I lost the pull.
I'll pull the first 3 logs off my laptop and post them here in a sec.
Old Nov 3, 2005 | 10:19 PM
4TUN8's Avatar
Here are the pulls....
File Type: zip
Old Nov 3, 2005 | 10:22 PM
Dave2's Avatar
where you mount your 02 sensor at?
Old Nov 3, 2005 | 11:49 PM
4TUN8's Avatar
rear o2 position. that should not effect readings, being as they put it in your tailpipe when you're on the dyno....
Or maybe you were just checking to make sure I didn't put it too close....It's right behind my cat delete...
Old Nov 4, 2005 | 03:33 PM
superman105's Avatar
did you calibrate the wideband first ?
Old Nov 4, 2005 | 03:49 PM
scherejs's Avatar
do you have a cat? because if you do then it will effect the readings bigtime.
Old Nov 4, 2005 | 03:51 PM
Willie Dynamite's Avatar
In his post that you quoted it say "cat delete".
Old Nov 4, 2005 | 03:53 PM
scherejs's Avatar
LOL I didn't even notice.
Old Nov 4, 2005 | 04:20 PM
Ev0ikon's Avatar
Calibrate my friend!
and don't mess with the fuel yet until you have done that.
Old Nov 4, 2005 | 04:26 PM
vboy425's Avatar
i have cat delete and i mount my Zeitronix wideband right there. it's works fine. crusing it's like 14.7afr, at WOT i try to tune my SAFC AFR between 10.8-11.5
Old Nov 4, 2005 | 07:31 PM
Dave2's Avatar
you should mount it on the DP. too far off from the turbo, it won't be accurate.
Old Nov 4, 2005 | 07:38 PM
warp9's Avatar
Are you sure about that?....Innovate suggests that further down stream is not only fine, but recommended....Should be the same for other brands
Old Nov 4, 2005 | 07:41 PM
Dave2's Avatar
i have TXS wideband. i just follow what the instruction said
Old Nov 4, 2005 | 07:49 PM
AznFlip's Avatar
Kinda off topic but....
How do you calibrate wideband anyways?
Old Nov 4, 2005 | 07:59 PM
4TUN8's Avatar
How do I calibrate it? From the instruction manual (this is the AEM UEGO gauge type controller) it says that it's calibrated from the factory....any help would be appreciated, but I searched here and I searched google for an answer to no avail.
