welcome to the maftpro forum
Originally Posted by TrinaBabe
I think you could get some better times by not lifting off the gas while shifting. It is pretty amazing that you can still hold that much boost between shifts Ill admit... normally the BOV will vent damn near all of the pressurized air out instantly. For me, I ran an 11.88 with lifting the gas and an 11.59 the very next run without lifting. Give it a whack... good luck with the clutch by doing this though.
Why did you set the RPM so high? I have mine set around 8250 (Stock Block/Head) and it works great. Only problem is the tires will break loose through 1st usually (Crap tires) but will also sometimes break when I hit second (Again, crap tires). When the tires hook though... hold on
Originally Posted by TTP Engineering
Many have had questions about what all is included, what are options, can it be run with or without the MAF, whether boost control is an option or if you can use your existing boost control and what options are required for a specific application. I have this diagram that should make things a little easier.
If there are any further questions, please ask them in this thread or PM us!
Illrunya
Jun 9, 2015 01:18 PM
Time for you to upgrade!!
