E-Manage Ultimate
Old Nov 21, 2008 | 05:21 PM
  #31
EvoIIIAj's Avatar
Hi..
Has anyone else learnt anymore on the E-Manage Ultimate?
Old Nov 26, 2008 | 08:00 AM
  #32
SAMIV80's Avatar
Yes I would like to know if this is as easy as the Cobb AP
Old Mar 15, 2009 | 05:06 PM
  #33
EvoIIIAj's Avatar
Can I download the e-manage support from anywhere, does anyone know?
Old Mar 15, 2009 | 05:17 PM
  #34
SparkTech's Avatar
We didn't have much luck with the E manage Ultimate
Support sucked and burnt coils...waste of time
Old Mar 15, 2009 | 08:13 PM
  #35
steadly2004's Avatar
Originally Posted by gunzo
hi.. yes you can.. but you need the greddy map sensor and you need to manually map each point into the map loadpoints
ie you gotta tell the EMU what equivalent maf is at that particular map point.. not easy but can be done
on top of that you need 2 adaptors in order for the direct injector control to work and ignition control..
theres still some minor issues but it seems to be working ok now
You don't need any adapters for the injectors, it does throw an SES for multiple injector malfunction without it. I never used it for ignition. Turned out ECuflash was better for my situation
I tried running this. And you don't have to manually input each value, you have the car run with the MAF installed and it generates a map, and air-hz out based on whats coming in and RPM/PSI. Then you copy paste this map onto your air-hz out and fill in the blanks. Not that hard.
In fact, I got mine running in about a day. The thing ran great, that is until the temperature changed. I was never able to get the e-manage ultimate to work with an air-temp correction. That meant tune in warm weather, and in cold weather you go lean, or visa versa. As far as I know, EVERY successful speed density solution uses a temperature reference for the calculations.
Now, I'm not an EVO, but a turbo'd Stratus currently running an EVO ECU, which turned out to be much more reliable.
Old May 9, 2009 | 10:36 AM
  #36
EvoIIIAj's Avatar
Hello.
Is there anywhere on the net that I can buy the support tool for the Ultimate?
Old May 27, 2009 | 12:54 PM
  #37
boostless's Avatar
the program for the Ultimate should be free. They usually send it through email. Give them a call.
Old Sep 13, 2009 | 08:44 AM
  #38
miksatx's Avatar
you can dl it at the greddy site.
i'm running a ultimate setup speed density on my mirage 1.8 turbo seems to be working fine. yep the greddy ppl stateside didn't know crap matter fact ah couple tuner shops couldn't figure it out either. i'm getting ready to add a flashable ecu so i can install bigger injectors. already am at max on my 565. hope to get a set of 1600cc an turn up the boost abit more
Old Oct 1, 2011 | 06:31 AM
  #39
Donovan81's Avatar
yeah i'm going to get the greddy pressure sensor but i wasn't sure if i should run the maf after the turbo to get the correct Hz reading and then copy it to the tuning map.I haven't put on my turbo kit yet and i'm trying to get all the info i can just so i don"t make a terminal error when i set up and start tuning
Old Oct 1, 2011 | 06:37 AM
  #40
Donovan81's Avatar
also i'm going to use a aem wideband setup what is a good a/f ratio to use for the auto tune function i have read that 12:1 is a good start point once i set up the unit should i use 12:1 as a start point and fine tune from there.any advice is greatly appreciated
TopSpeedAutoSport
EvoX 'For Sale' Electronics / Lighting / Audio
102
May 6, 2011 03:46 PM
InjectedPerformance
Evo 'For Sale' Electronics / Lighting / Audio
18
May 11, 2010 01:46 PM
Gruppe-S
147
Nov 18, 2008 10:53 AM
DrivelineSales
Aug 6, 2007 12:21 PM
