Aux Outputs
Old Dec 3, 2005 | 05:26 AM
wspy's Avatar
Aux Outputs
I understand that a few features are in the works such as timing and launch control, and frankly i personnally can't wait for their release!
I currently use a MAP ECU on my EVO 7 ,which works fine, but does not have the adjustability of the Translator!
What it does have is a NOS control section which allows you to operate a NOS sys as per rpm on/off as well as boost on point!
Any intentions of adding such a section to the MAFTpro and if not may I make the suggestion.
Howadoudit Turbobob
I will be switching to the MAPTpro as soon as the timing feature is introduced for the EVO
Thanks
Mark
Old Dec 4, 2005 | 08:25 PM
TurboBob's Avatar
There is one extra output that could be set up as a window switch / N2O control......
Let me get this other stuff done, and I will look into adding that.... For now, the boost control output could be set to do most of that.....
Bob
