PLX R-500 Wideband A/F Computer, anyone using this?
Old Dec 10, 2005 | 11:20 AM
evoate ya's Avatar
Just saw this in Turbo Magazine and was interested so I went to their website, heres a link:
http://www.plxdevices.com/R-500_productinfo.htm
The r-500 seems like a good monitoring tool. WB 02, EGT, Knock, and Boost monitoring. 6 Inputs for data logging, 4 analog outputs, Fully customizable LED warning light or shift light, and a few other things. The one thing I found to be pretty cool is the ability to remove your primary narrowband stock 02 sensor, and replace it with the bosch wideband. The controller then takes the wideband o2 input and converts it to a 0-1 volt output that can be sent to the stock ecu to maintain closedloop o2 operation. I would think think there are some benifits to running this way? One, no need to add another bung for the additional sensor ( not really a big deal) and two, I would think using the wideband sensor as the primary output to the ecu for controlling the A/F ratios would result in way more accurate readings than the stock sensor. This would result in more accurate fueltrims, am I correct.?.
Plus it has the ability to monitor knock, egt, and boost pressure. This sounds like it would be a pretty nice addition for the evo. I am getting wideband anyway and have been looking into the knocklink for monitoring knock as well. So to get it all in one would be great. The unit is a bit pricey, but for what it includes I think the price is fair.
Does anyone have any experience with the PLX R-500, if so, feedback would be greatly appreciated. And also if my theory on the control ability with this setup is off, please feel free to correct me.
Thanks
Old Dec 15, 2005 | 03:44 PM
streetrays's Avatar
well, it seems like you've recognized many of the features. from a vendor point of view, we can confidently say that PLX units have high quality as every unit marked as tested are actually being tested repeatedly through many processes.
furthermore, R-500 firmware is always updated (manually by re-flash), and during this holiday season, you get free g-sensor so you ALREADY will have onboard dyno for free. if you get the optional EGT kit, then you have the FULL array of R-500 functionalities. you can either check out www.plxdevices.com or www.streetrays.com (search for R-500) for FULL details.
Also, R-300 (the little brother of R-500) has been released and is now shipping. so you can check that one too.
Old Dec 15, 2005 | 03:57 PM
streetrays's Avatar
BTW, which mag did you get the ads from anyway..
Old Dec 16, 2005 | 01:57 PM
evoate ya's Avatar
I believe it was in the jan 06 issue of Turbo, cant tell you for sure, I left the mag at work. It was either Turbo or the newest issue of Modified. Thanks for your input, when I decide what to do I will give you a shout
Old Jan 10, 2006 | 01:58 AM
silex's Avatar
How did you guys hook up the boost portion of the R-500? I checked the white papers and it doesn't have the parameters for the Evo.
HiVoltEVO8
49
May 11, 2006 11:50 AM
streetrays
19
Jan 24, 2006 08:16 PM
Nesiop
20
Jan 14, 2006 07:48 AM
Gruppe-S
Gruppe-S Engineering - California
Jan 4, 2006 03:35 AM
Gruppe-S
47
May 23, 2005 10:48 AM
