Max HZ numbers???
Old Dec 13, 2005 | 12:01 PM
jid2's Avatar
Max HZ numbers???
Just a question for AFC users running the stock turbo... What is your maximum value for HZ that you have seen? List your mods, and boost level. This is a nice way to see how much air (which makes power) peoples car are pushing
I'll start.
1800 Hz @ 7500 rpm
03 stock turbo (9.8T)
3 in TBE no cat
3 in Intake
MBC @ 21 psi (max)
Upper IC Pipes
264's
Fuel Pump
Dynoflash mail-in
Old Dec 13, 2005 | 12:13 PM
Warrtalon's Avatar
Max Karman readings?
As an update for me, I currently see a max of ~1870-1880 at 24psi on race gas while running 12.0s at 113+.
- Catless TBE
- Walbro 255
- K&N drop-in
- MR DV
- Hallman Pro MBC
- Dynoflash
- SAFC (adjusted when using race gas)
Old Dec 13, 2005 | 07:08 PM
jid2's Avatar
Thanks for the pointer to the other thread.
Old Dec 19, 2005 | 08:44 PM
TTP Engineering's Avatar
2126hz max at whatever the stocker could put out with the hallman cranked to the max and an injen intake cone.
Old Jan 7, 2006 | 07:06 PM
blowoffsilver's Avatar
2496 karman hzs it was on the dyno peaking 30psi on my greddy kit i put down 445hp on a mustang dyno but on 25psio it would hit around 2200, and on 20psi it would hit around 1980
