Scanmaster 3 and ECU+
Old Jan 18, 2006 | 01:22 PM
sponge bob's Avatar
Has anyone used Scan-master 3i in conjunction with ECU +, are there any compatibility issues?
Old Jan 18, 2006 | 08:27 PM
tlcoll1's Avatar
The ECU+ includes a full OBD-II scan tool, so you wouldn't tend to use it and the Scanmaster together. But if you want to, you can pop a jumper inside the ECU+ to disconnect it from the OBD-II lines, thus allowing the Scanmaster to work. OBD-II only allows one "master" on the bus, and the ECU+ is it by default.
Tom
Old Jan 19, 2006 | 01:33 AM
sponge bob's Avatar
Ok, makes sense. Thanks, and thanks for all you other responses.
