EGR Removal
Old Jan 31, 2006 | 10:02 AM
zze131's Avatar
EGR Removal
Hey guys, after doing a search through the site I still have a couple questions about removing the EGR system. I had my intake manifold off (to replace the gasket) and it was really dirty inside.
Obviously there is a block-off I can get, but I'm wondering....
-How I would be able to completely remove the EGR system? (any DIYs?)
-Is there a particular ecu setup that will allow me to go without?
-What would be the side affects be? (I have a few assumptions).
Oh yea... and where is warrtalon going? Colorado?
Old Feb 2, 2006 | 06:27 AM
Dorikun's Avatar
In Japan(US too), when they do race cars they remove it... technically I think if you straight up removed it, it would be fine but I think you would get an engine light because the way the vacumme on the system is set up for air emissions purposes. You'ld have to get the ECU flashed for that I think... but if you can get it off, more power to you, I like cleaner looking engine bays. You might get an engine light for exhaust/gas leak.
Old Feb 2, 2006 | 06:32 AM
Dorikun's Avatar
man... becareful on this one... a second thought tells me this is not street legal...
http://www.specialtyz.com/300degree.htm <bottom of page) an example of an egr removal kit.
Old Feb 25, 2006 | 09:26 AM
honki24's Avatar
I hear "dont do it all the time" but I plan to. How does the ecu know whether it is working or not so I can trick it? There are no sensors on the actual EGR valve.... Also, you dont really need a blockoff plate, just pull and plug the vacuum lines I would think.
Old Mar 2, 2006 | 10:37 AM
Sleeper2G's Avatar
On the DSM's when we would pull them off we ran a vac. line from one nipple to the other. I haven't looked at the EGR on the EVO yet, but if you used the plugs they blow off the nipples easy on DSMs
fostytou
359
Oct 23, 2025 09:54 AM
LakerRaider
May 17, 2017 04:20 PM
slowsrt4:(
Apr 19, 2014 03:46 PM
2004EvoVIII
Oct 31, 2012 01:29 PM
mooreboost
16
Apr 19, 2005 09:08 AM
