ecu+, 50trim, 750cc inj
UPDATE: ecu+, 50trim, 750cc inj
I have an evo and eclipse. This is my log with my eclipse gst. Intake, fmic, tbe agp rs49t, 750cc, walbro255, 15 psi. I read up to 2 counts of knock. How can I eliminat this? I would like to turn the boost up, can I? Where should I start to make adjustments? I have a aem uego in the mail...
Here is the file, thanks for being patient.
Originally Posted by Ev0ikon
err... are you serious?
Originally Posted by Ivan_C
Easiest way to get a log file up here is to zip it up.
Ivan
Ivan
what program do you need to view the file? but if your seeing knock just remove 1-3 degrees of timing around the rpm range your seeing the knock. If you turn the boost up, add fuel to compensate for the extra air the engine is seeing.
