datalogging wideband signal with pocket logger
Hi everyone
maybe this have been covered before.
but following is how to log Wideband signal with pocket logger
1) Have a working Wideband device that have a output wire and set it up to linear
0-1v output (if using AEM UEGO GAUGE TYPE WIDE BAND use P03 or P02 Setting)
2) Cut the wire that leads to Pin 75 on the ECU. This wire is the input for your Rear O2 Sensor
3) Connect your wideband 0-1V signal wire directly to the wire that leads to Pin 75 on the ECU
4) you may now start up your car, Turn on Pocket logger and select O2 2 bank 1 in the datalogging section if you see the numbers moving then you have set it up correctly.
sorry I didn't take any pictures
