Boost controler issue
Old Feb 25, 2006 | 07:20 PM
andross85's Avatar
I am already have a Apexi AVCR... do you guys think the turbo controler come along with the utec is better than that, or the AVCR is better?
If AVCR is much better, i will keep it
Old Feb 26, 2006 | 11:39 AM
bbbwrx's Avatar
The good thing about using the TurboXS BC option is that you can control it in closed loop. So you set the boost levels and the BCS will try and hit the target Boost level.
The AVCR can do boost control very well. and would not be hard to tune because your tune should go like this
boost --> fuel --> timing
Timing and fuel can be switched but you should always tune the load first.
Ben
Old Mar 4, 2006 | 01:04 PM
EvoG8r's Avatar
I want to try using the UTEC with BC, but there is no way to know for sure if it will perform as well as an EBC? I was thinking of selling my Greddy EBC and just going with a UTEC with BC.
