gasket problem
Old Feb 28, 2006 | 12:39 PM
GT35 over boost's Avatar
Question gasket problem
hi to u all
i have problem with mi evo 8
i change the engine gasket for 3 time and the car is not runing lean so what do you think the problem
Old Feb 28, 2006 | 12:54 PM
Inn-Tune's Avatar
Did the car ever overheat? Maybe the deck isn't true anymore? Need more info...
Are you on a rebuilt engine? Did you re-use factory head studs when replacing the gasket?
Old Feb 28, 2006 | 12:57 PM
Curt@MrLed's Avatar
Former Vendor
wow, we need more info.. but ill take a guess, youre running a 35r and your not tuned right..
Old Feb 28, 2006 | 12:59 PM
yes on a rebuilt engine ,no factory head studs
Old Feb 28, 2006 | 01:35 PM
Inn-Tune's Avatar
Was the block and head checked for true properly? ARP studs?
