Nitrous Control
Old Mar 29, 2006 | 11:57 AM
rugarip's Avatar
Nitrous Control
Are there future plans for ECU+ to incorporate a nitrous controller to the unit. I would not be using this for Nitrous but for a meth pump instead. I think that once boost control is added plus having the ability for nitrous/meth would make this "piggyback" the best out there hands down. I will be purchasing one regardless if these to features get added but if they did my life would be great.
Old Mar 29, 2006 | 10:02 PM
tlcoll1's Avatar
No current plans. I think in another thread the idea was suggested that the ECU+ switch maps based on an external input, where that input was driven by an external nitrous/meth/alchohol controller's "on" signal. That seems more likely in a shorter term than having the ECU+ *be* the controller.
To be the nitrous controller, what kind of device would the ECU+ have to drive?
Tom
Old Mar 31, 2006 | 08:05 AM
rugarip's Avatar
I like the "short term" goal you stated. If it could switch maps based on that input being turned on would be pretty close to what it needs to do. I know you are working on boost control as well, and when those maps are swithced the boost would need to be turned up as well. This would definetly work for what I am planning to do. Thanks.
Phil
