getting in touch with autronic
Old Mar 31, 2006 | 01:35 PM
SLW EVO's Avatar
Hey, does anyone know if theres a way to get in touch with autronic directly?
i'm tryign to do a intake manifold replacment (ams's one) and for some reason it does not want to work. the car will not make consistant runs and therefore, is not tunable. Anyway, the manifold install requires you to take out the evap/emission solenoid. i'm not sure if the autronic needs that.. so i want to ask them directly. If it doesn't need it, i'll go look elsewhere for teh problem
please let me know
mike
Old Mar 31, 2006 | 02:45 PM
Wangracing's Avatar
Contact details are at
Autronic
The best person to speak to is Ray Hall in queensland Aistralia.
But if I was to guess, from my experience with it in rexes, there is the intake air temp sensor which is plumbed into the intake which you will need to have relocated and in the case of the rex the autronic used the idle stepped motor to control idle when using accessories (air con) etc.
Old Apr 2, 2006 | 07:20 PM
fatbastard's Avatar
please let me know
mike
assuming that you are using the PnP unit, there are no sensors used by the autronic that are in the intake manifold (unless the air temperature sensor was placed there)
